BritishGypsum
How about fibres incorporated into multi?
Could you expand on that?
What's BG's favouretest Labrador colour ?
Hi @gps,
UniFinish is available at Travis Perkins and a number of other stockists – if you’d like to try it give us a call and we’ll find your nearest (we can give you some options if you don’t want to go to certain ones!) We have done trials with B&Q and hope it will be available there soon – it would do us a favour if you could ask your preferred supplier to stock it!
No problem, thanks for asking, hopefully it will be in there soon!thanks for the reply, its never going to take off in travis perkins though, you need to get it into wickes/b&q thats where domestic plasterers get 90% of their gear and surely thats your target market for this,
@BritishGypsum When uni finish 2 fails are you going to put your hands in your pockets and compensate the lads losses ???
Hi @theclemo - this is a tricky one – there is no single cause so no “magic bullet” to stop it. It tends to be more likely if:
1) The site weather is cold
2) The plaster is mixed much more than necessary
3) More water is used during trowelling up
4) The final trowel is done with a high trowel angle (some call this a “cutting” action – the opposite of a flat angle)
The best way to avoid it, e.g. in cold weather, is to try to work neatly and get the surface flat early, so there is less need to move material around later – it’s this that seems to make it show up. Hope this helps!
I have tried all the above and still get them in bg multi. But don't get them in irish gyproc skim.
How is durafinish different to unifinish as they are both able to adhere to smooth surfaces with no need of pva but durafinish cannot go onto a well keyed browning or hardwall without the need for gyprime?!
Can unifinish be applied to a painted surface flattened but second coated with multi or board finish?
James the problem with fibres in the plaster is they'd be in the topcoat too and risk showing through. I only ever put a handful in my first coat then second coat as normal
Cos they haven't got a clue what they're doingCan I just ask why you do this, for our understanding?
Those fibres from wickes and Source 4 Me are very good and dont show through top coat but i usually just put plenty in the first mix and in undercoats. I sprinkle them into the water and wisk through before adding powder not sprinkle into the plaster.Having said that ive never tried them in the top coat? Just assumed it'd be risky
Okay, time to sign off now, but thanks for all your questions, hope it's been useful.
We'll be doing another Q&A in a couple of months so we'll keep you updated on that, but in the meantime let us know any other questions!
Thanks,
Steve
Thanks,
Steve
s**t I missed itso is it safe to use unifinish?
Hi @Danny,
It’s a combination of all these: if it was a simple material problem we would be able to fix it but unfortunately it’s usually a complex mix of things including the environment and site conditions – it wouldn’t just be down to user error
british gypsum aint a bad price, though, for most products. ill give them that. i went over to ccf in liverpool today and got 15 mp finish. ended up paying 8.40 a bagthis was after i phoned them and got quoted 7.23 a bag
in that its part of tp i should have known. w4nkers. anyway as i was leaving the job tonight i noticed the side of the bags say use by 23 /3 / 2015
so not only rip me off but sell me out of date gear. sums up knaufs problem. selling it through merchants that make up the prices as they go rather than putting it in wickes. so will go and do a little patch job somewhere else in the morning then take all the gear back to them in the afternoon and get back my money and stick to bg
hews grey, went in there a few months back and was asked for 3.95 for one 8 foot beaddont have an account with them but they could see me covered in plaster and the van outside. dicks. great way to drum up future business
we get all our gear from travis, good prices and personal terms with all lads in depot now, nothing too much trouble there, deliveries when we want themTravis Perkins are shite and overpriced plus the yard lads generally useless and lazy !! (up north)
Must just be up north then pal s**t prices s**t everything !!!we get all our gear from travis, good prices and personal terms with all lads in depot now, nothing too much trouble there, deliveries when we want them
